Failed to look up interface address using ioctl(SIOCGIFADDR).
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Error
Failed to get interface IP address. Sockets error code = %p1% Interface index = %p2% Socket ID = %p3% Socket type = %p4% Socket family = %p5% Socket protocol = %p6% Application handle = %p7% Stub socket handle = %p8%
Name | Type |
p1 | sInt |
p2 | uInt32 |
p3 | sInt |
p4 | xInt32 |
p5 | xInt32 |
p6 | xInt32 |
p7 | uInt32 |
p8 | uInt32 |
